I just finished my first knife about a week ago. I'm currently doing some edge holding testing on cardboard, using a BM Ares in 154CM as a standard. The blade on the home made knife is O1 by Starret. After sharpening I pressed it against the edge of an old Buck Scoutlite and it notched the Buck w/o any noticable effect on the O1. The Scoutlite was Buck's old 425 Modified. I didnt test the hardness of the home made, but I quenched and tempered another piece and it was 56-57 Rc. I'm up to 360 cuts on the Ares and it still shaves hair. Both were sharpened on the Sharpmaker to the brown flats. Here's where my questions start. The O1 would cut free hair held between my fingers off the brown stones, but the 154CM would not. Both would shave hair from my arm. Any idea why the difference? I dont really have any data or other info, I'm just happy my first attempt seems to have worked out the way I wanted. Geometry on the home made is full flat grind on 1/8" x 1" stock, about 3.75" blade length. It was 4", but after tempering, it warped and I broke the tip off trying to straighten it. The edge thickness before sharpening was ~1/32", maybe less, I dont have anything accurate enough to go below that. Any other common materials that I could use to test sharpness? I may be able to get some rope from the shop, but they use it and are pretty stingy. I've also thrown the O1 knife (and the Ares, but thats a different story) and only had a few scratches, no damage. Its very light, probably 3-4 ounces, but I dont have a scale to measure low enough. My bathroom scale measures to 1/10 lb, but doesnt show any change. Its a clip point, and was designed as a hunting knife. The fit into the handle could be better, but it works, and there's a small gap at the spine into the handle, 0.01" or so.
