- Oct 2, 2015
1500 grit is far beyond over kill on birch. 220 is considered fine enough, 400 is really as far as it goes. On denser woods like rosewoods and ebonys, the grain is much much finer and thus can take a finer polish. There is no reason to overwork yourself sanding any higher than 400. nice work though!
they really work much the same. i dis-agree with hellspawn415 on the sanding though. the higher you go the sweeter it'll feel. you do have to watch out for feathering out, but if that does happen you can stiffen the fibers with shellac or even thin superglue(cyanoacrylate). just make sure you get rid of all the superglue or you'll have splotches in your finish. 1500 is not overkill, the wood loves it and it'll feel like silk. not trying to start an argument here, i've just worked with alot of birch, maple and willow.
http://www.popularwoodworking.com/techniques/rules_for_sanding_wood
http://www.thewoodwhisperer.com/articles/sanding-too-much/
The reason it feels smoother is that you are burnishing the surface. The grain in birch, maple and walnut is simply to large to benefit from the sanding. If you want to get a wood glassy smooth, you would be better served by using a wood with a finer gran like rosewood, ebony, ironwood or by using a stabilized wood.
as long as it got darker even after drying you should be good. if you don't like it just apply another coat wet sanding. it'll build up,up to a point and that's a good thing. and remember you can always go down a grit as long as you bring it back up. tung oil is super user friendly(hard to f--k up to be blunt) so you should be good to go![]()
those are nice articles, but i will note that flexner commonly stains his projects in addition to finishing them. i tend to use a natural danish oil to allow the lustre of the wood to show. i find that wet-sanding through the higher grits adds considerably to the overall feel of the finish and hence, the piece.walnut and birch are two very dissimilar woods in terms of grain and overall fiber structure(i.e., one is porous and one is not). in sanding walnut 400 would certainly be fine given that you are using some type of penetrating oil finish.i would highly recommend wet sanding at least one coat if not more.you'll be amazed at the sensuous feeling. personally i'd go up to 600 if you can,but that's me. if you're using a lacquer type finish i would start as high as you feel will get imperfections out and go up from there. sanding sealer would be a good idea with a lacquer type finish as walnut has a porous surface.(that's one reason i like wet sanding oils-it creates a slurry that fills pores up-thus adding to the rich texture). scraping and/or burnishing are also nice ways to finish wood so as to remove sanding almost altogether-and the dust that comes with it. i hope i'm not offending anyone-i've been around and been a carpenter since about 5-and now i just turned 45. seems like it was yesterday when i bent my first nail(laugh). in the end it's what works for you, there is no "one way" to do things-but i would go with the grain on that walnut.![]()
