Finishing Ironwood
donnord
I am in the process of making some iron wood scales and I am not getting much pop out of the wood by wet sanding to 800 grit. I am thinking about wet sanding 1000 and 1500 with tung oil to see if that will bring out the pop. I know iron wood is oily, would the tung oil cause any issues with the ironwood?
Might get more responses in the shop talk forum but I’ll tag a maker here that really knows how to finish out Ironwood nice and maybe will pop in and help blgoode blgoode
I make cane handles out of Ironwood from time to time, and not all Ironwoods are the same. They can react quite differently to stains and oils between different species. I prefer to just take mine down to 800 grit and then steel wool. I don't like a coating oil on wood that's already got oil in it, but that's just me. I use a small amount of paste wax and buff to work it into the grain for better hand feel.
So I think Have some "exhibition grade" scales that were not graded correctly. Yes there is some burl / swirl, but the dark part which is mot of the handle is just dark. See the pics. Twice now I have taken them from 80 grit to 2000 and result is the same each time. I was actually thinking whoever made the scale blanks may have overheated them. I know I have more work to do on them anyway as there are few scratches still visable. But I wondering if the effort is worth it.
You can make a fill for those cracks by mixing up some epoxy and some of the sanding dust from the scales. They look too deep to sand out without losing a lot of material. Given the tearout around the countersink holes and the pop of the grain, I would call this either a species that is more "splitty" or one that came from a much different climate zone than where the scales are or were stored. Once the cracks are patched and it's had another 800 grit sanding, try wiping it with mineral oil to see if it gets the shine you want and if the grain swells a bit more full. If that's the kind of look you want, then a coat of poly finish will replicate that effect, but test it in a small area first. The species looks like a "Desert Ironwood" I got off the shelf at Rockler one day, and if that's the case, then a finish in Boiled Linsee Oil will really help fill in the grain along the finger wells.
The scales don't look burned to me since the drill holes show some lighter wood even though it looks like the bits were dull judging by the level of polish and roughness. You could check by sanding the insides of the scales back to 60 grit and seeing if they change color appreciably. If nothing else, finishing these scales will be informative and good practice for the next time.
