Finishing Stabilized Wood
The following is based on my experience working with wood stabilized by K&G. It is based on my hands on experience and my opinions. This is not the only right way, but a fairly easy method that will consistently give good results when working with stabilized woods. You might have your own method that you like better. The purpose of this thread is to answer re-occuring questions about how to bring out the full potential in stabilized woods
Working with stabilized wood is a lot like using natural, non-treated woods. It can be worked using the same tools and abrasives as with natural woods. The stabilizing process will even up the hardness of the wood as well as fill in a portion of the open pores in the wood. This makes the wood easier to sand and get an even finish that will often times show off the grain patterns and figure in the wood better than the results obtained using the same procedures with natural wood.
Not all stabilized woods will be the same hardness. Some types of wood will not attain the same hardness as others. While the hardness and durability are improved by the stabilizing, care should be taken when working with them. Examples would be some Spalted woods, Redwood and Walnut. These are best worked by hand after rough shaping. Power sanding will remove material faster than harder woods so attention is required when working with these.
Care should also be taken when power grinding/sanding stabilized wood to avoid overheating the material. Using sharp abrasives and not applying excessive pressure helps to avoid overheating. Once again, paying attention to what is happening with the wood can help to avoid problems. Overheating can cause warping and cracks much the same as when working with other natural or manmade handle materials. Easiest way to avoid problems is to throw away abrasive belts when they start to become dull and take your time when sanding and shaping.
The old school way of finishing stabilized wood is to sand to the desired grit and then power buff with no external finish being applied. The early woods that got stabilized were primarily light color, small pore, non-oily woods such as maple, ash and box elder. Even to this day these woods are best in how they respond to stabilizing and ease of finishing by just sanding and buffing.
Now days many different woods get stabilized that the early stabilizers were unable to stabilize successfully. This is the result of years of experimentation resulting in modifications of the equipment used and in some cases different formulations of the chemicals used for different types of wood. Now many of the denser, oily and open pore woods can be stabilized with very good results making the wood more durable and easier to finish than their natural counterparts. As an example some stabilizing companies will use a thicker formula on the softer and open pore woods and a different thinner formula on denser and oily woods.
While these woods can be finished using the sand and buff method, better results can be obtained by doing things a bit differently. The steps I mention below can be used with all stabilized woods to obtain great results with minimal extra work.
1st step – After you have sanded to the desired grit, blow off any dust using compressed air. If you don’t have an air compressor you can used canned air that you get at an office supply store. (used to blow dust from your computer) When you have a dust free surface apply an oil blend (Tung Oil, Danish Oil or Tru-Oil) finish by putting a couple drops on your fingertip and rub in thoroughly. Let that sit from 15 to 30 minutes and then wipe down thoroughly with a soft cloth. Repeat once or twice until you like how the handle looks. Applying the oil blend finish will brighten the colors in the wood and give more depth to the figure in the wood. Using an oil blend also helps to fill any small open pores in the wood enabling the light to refract clearly to show crisp, well defined grain patterns.
2nd step (optional) This step is for open pore and coarse grain woods such as Walnut and Oak. Wet sanding works well as a method to fill open pores in wood. Apply a liberal coat of oil blend and use wet/dry sandpaper to rub down the stabilized wood. This will make a slurry of the oil and sanding dust that fills the open pores in the wood. Let this slurry dry without wiping away the residue. That allows the slurry to dry and harden inside the open pores. Depending on the wood you will need to repeat this 3 or more times. When it looks like you have a good smooth surface (pores filled) allow that coat of oil to dry. Then apply one last coat of oil, wet sanding the surface followed by wiping thoroughly with a soft cloth.
3rd step – Apply a paste wax designed for wood (I use Minwax brand wood finishing paste wax) using a soft cloth in the same way as polishing a pair of leather shoes. Let the wax dry for at least 15 minutes and apply a second coat of wax. Let the second coat dry about a half hour. Then buff by hand using a soft cloth.
I am against power buffing unless you are very experienced with a power buffer and have a very light touch. First of all the power buffer can be one of the most dangerous tools in your shop. Just a fraction of a second distraction is all it takes to grab the piece you are working and throw it across the shop (if you are lucky). Power buffing can also fill any open pores with buffing compound. Also the figure in some of the flashier figured woods can be diminished by power buffing because if you do not have a light touch the surface of the wood gets burnished fixing the figure in one place, eliminating much of the movement and the chatoyance in the wood. Some woods will even get a smeared muddy look from power buffing. Hand buffing with a soft cloth will enable the figure to maintain the metallic flash and holographic look, where the figure changes shape and seems to move around beneath the surface of the wood.
Disclaimer;
There is no single correct way to finish stabilized wood. You need to experiment and discover the way that produces the results that you like best. The methods I mentioned above may be contrary to the methods used by many skilled knife makers. Some knife makers are able to get very good results by using the sand and buff method. The methods I mentioned can attain very good results and will work well on all stabilized woods. This method allows experienced knife makers as well as beginners to bring out the full potential in the stabilized woods that they use. These methods also work well with most natural hardwoods.
Questions, comments and how you finish stabilized woods are welcome.
I would really like to hear from some of you who have their own variations of how to finish handle material.
By picking up a good tip here and there we can all get better at what we do. At least that is how I learn. I do things a lot different now than I did just a few years ago.
If you read through this and think I am totally off base, you are welcome to say so.
But please post a better way to do things if that is the case.
I have a glass jar, from a frappuccino, I think, that I keep my teak oil in. I usually put a 600 or 800 grit finish on the wood. Then I immerse the handle in the jar for a minute or so, then wipe off the excess and let it dry for 15-30 minutes. Then I put on a second light coat with a cloth, like you described in your first step. Then I wipe it off and let it dry, then a coat of Ren-wax. Pretty much the same as you descibed, except for the initial brief soak.
I hand finish to 1000 grit, wipe with damp cloth to remove residue, allow to dry and apply/hand buff with 8000 grit diamond paste. Thanks for posting your method. Think I'll try it.
Brett
Ever learning, I appreciate threads like this.
I used a CA finish on stabilized fiddleback maple (I think?), then buffed with microfiber and white (plastic) compound. I really like the results, but have wondered what else I could do to bring out the full potential of stabilized wood.
Hey, Mark - thanks for the post. I've tried the wet sanding approach, and it does result in a much smoother final appearance - but at the expense of some "clarity" in the wood. My theory is that the sanding residue (dust) fills the pores and can also leave a thin film on the surface. If a wood is really porous and I want to smooth it out, I'll wet sand with TruOil, let it cure, and sand back down almost to bare wood again. This leaves the sanding residue just in the pores. Then I finish the scales with regular (non-wet-sanded) TruOil - applied thin, wiped down, cured, and reapplied up to 10 or more coats.
On some woods where I want a more "natural" feel (like stabilized masur birch), I'll sand down to 1200 grit and then just top with a couple of coats of Ren Wax. This provides a soft luster with a warm feeling in-hand. Perfect for a Scandinavian knife.
Cheers!
TedP
Just a question here, can you cut stabilized wood using normal wood tools (handsaw, bandsaw) or do they need different blades? Thanks
You can use the same wood tools and abrasives as you would for unstabilized woods.
A suggestion for cleaning the dust off the scales. An air compressor works fine but a less messy method is to use a tac rag. They only cost about a buck apiece and by refolding them after each wipe/pass, they will last quite a while.
Tim
I have some questions for those of you who are using Tung Oil, as I have never used any before. After doing some reading, I have learned there are different variations of Tung oil. Basically there is 100% pure Tung Oil, Polymerized Tung Oil (has been through a cooking process to partially complete the molecular process that drying oils go through), and Tung Oil Finish (which contains only a small amount of tung oil and some do not contain any tung oil at all).
Can you tell me which variation you are using? Which brand, specifically, are you using? What is your specific method of application? How long is your drying time between coats? How many coats do you apply?
Lots of questions I know, but I want to be more informed before purchasing and trying this out. I have not been using any oil at all on stabilized wood up to this point. Basically, just finishing to a high grit and hand buffing.
I have not used Tung Oil myself.
What I use for my projects is Watco brand Danish oil.
I would look for a tung oil that is a blend. That way it helps to build up a slight surface finish as well as brightening the coloring in the wood.
I realize this is an old thread, but I’ve been trying to figure out how to fix some of this burnishing that’s been created when using a belt sander on spalted maple, which has already been stabilized. I have slabs of spalted maple, and I’ve been cutting them into smaller pieces, usually 6x2x2, then stabilizing them. After they’ve been stabilized, if I hit the wood with a belt sander to remove some of the dried resin or trying to shape the wood into a specific size, where I’ve hit it with the belt sander produces a darkened area on the wood which almost looks wet. It’s much darker than the surface of the wood that wasn’t sanded. If I try to trim it down using my table saw, the entire cut side looks like this as well so I’m assuming it probably has something to do with the heat generated on the piece of stabilized spalted maple. Is there any way to remove these darkened areas on the wood once this has happened? In the future, I guess it might be best to hand sand the stabilized block of wood instead of using the belt sander or anything else that would generate heat on the material. I just have a lot of pieces of this stabilized spalted maple with dark spots on them from using the belt sander so I’m trying to figure out how to fix this so the blanks look more uniform in color. When I say "dark spots", it looks burnished from where heat was generated on the stabilized spalted maple. I don’t have this issue much on other types of wood so it must be the lighter color of the wood that makes this more noticeable. Thanks!
