[youtube]LZ0epRjfGLw[/youtube]
But really though...it depends on how much you use it. It will last a long time...or a really long time.
I think I got one in Late 2008 or early 2009 and I just change the rod in one. I used it @ every camp-out
but again everyone useage is Different.
Some folk may scrape & scrape and are hard press for a fire due to tinder or lack there of good quality tinder.....
I'd say I got a good solid year out of mine w/o a Doubt :thumbup:![]()
Tony,
you probably already answered this in another thread, but when you replaced your rod, did you go tap and die method or epoxy?
I have a new style (Rowen manufactured) that is epoxied in. I was wondering how hard the switch would be. Dunno if the metal would take a tap well or if I should just use Gorilla glue.
maybe I should just buy another to experiment on.
All my ESEE fire Kits are the older versions except one.....and even my newer version will be replaceable after rod is used up, I will not expoy another rod inplace....
The one I replaced had a replaceable rod meaning if you look into the storage area inside the capsule you'd see a screw head. if so, undo screw ... drill & tap rod and good to go...just FYI ,I used blue loc-tie on mine just b/c.
If you have the non replaceable verson I am sure you can do the same but alittle more work... just use a 3/8"diameter by any length you like
Yes just a Few
Where did you get the bic lighter sheath? or did you make it? do your kids have cool gear like this too??
