- Mar 14, 2009
So last weekend I was camped out at just over 11,000 feet altitude - just a few hundred feet shy of the treeline. At this altitude, your options for wood are pine, pine, and more pine. The plus side is that, since it's so dry at those altitudes, and the sun is so intense, there is generally a lot of dry fuel available - plenty of scrubby grasses and lichens and so forth.
The downside, however, is that the available wood can tend to be pretty lousy. One thing that was driving me nuts, was that the wood was almost too dry. Most of it was almost like balsa wood in weight, but also really crumbly. None of the stuff I'd normally do at sane altitudes as far as wood processing with a knife was working with this fuel - try to make curls and you'd get tiny chips and maybe a bit of dust, try to split it, and you break off an inch long piece, and so on. Even though it was quite dry, and there was a lot of fuel available, it probably took me twice as long to start a fire as normally. You would expect, with the very dry conditions, that it would have been a lot easier than it was, but I found it to be a real pain in the butt, and well outside my comfort zone. I got flame in large bundles of dry grass several times, with the flame burning out without catching anything else, and it took several tries to get that grass to actually catch anything. I've never had so much trouble with so much dry fuel.
Has anyone done much fire building at these sorts of elevations? Any tips for getting your materials prepped for your fire? Could the reduced oxygen be part of the problem, or was it more likely to be caused by my own ineptitude?
