"Fire Pipes"--Any interest?
FortyTwoBlades
Baryonyx walkeri
Dealer / Materials Provider
A piece of kit I like to carry is a 6" section of an Easton "Jazz" arrow shaft for use as a lung-powered bellows. It concentrates the breath to a TREMENDOUS degree and makes breathing a fire to life a lot less of a hassle. I found a good source for some .035"-walled 1/4" aluminum tube and thought it might make a sturdier but still light-weight alternative to an old arrow shaft. I'd cut the the tubing to length and bevel the ends to round off the sharp edge. Any interest in such a thing?
I use an 11' aluminum straw from 7/11. 99cents & weighs next to nothing. Even comes anodized in safety orange. Well, & a few other colors too, but I see the orange the most.
I've got a couple of bits of old radio aerial I use for that. They telescope from about 3-4” to more than 12”. Keeps the face out the smoke and lets you keep blowing and seeing when doing a project using a hot coal to burn through blah.
Oh wow--had no idea about those. Thanks!
Actually, looking at those online they seem to be a bigger diameter than I like to use for this purpose.
I use surgical tubing, about 24" long, with a brass tube on the end (about 4" long). I can get real far away from the smoke.
Soft Copper tubing works well too. Try pinching one end for better performance.
I use a pencil-sized basswood or cottonwood branch. A small length of steel wire heated red hot and pushed through the pith makes a 'natural' looking fire pipe.
The nice thing about using thin tubing is that it takes up less space for the same effect. A good method, all the same. :)
I carry a fabric stretched over a wire frisbee for fanning the flames once I have the fire going. It was free at a convention. I never thought about using an aid to fire the initial fire going. I didn't know 7-11 sold aluminum straws for slurpees. I should pick a few up. I was going to order a titanium one at some point.
I make a small hole using my forefingers and thumbs. No weight and I can stay a couple of feet from the fire. Very effective too.
With the size of those straws (one fellow online was saying you could suck up a Bic pen in one) you might want to gently crimp one end.
I like that surgical tube idea horny toad, compact and I'm sure it would come in handy for other tasks too.
Rick told me of a brass tube he carries in his kit for the same purpose , also useful as a drinking tube and other things. Definately something I am going to add to my kit. I'm going to try and find a stainless steel one. 6" seems a bit short though ; I might go a bit longer like 10". I can always reduce it if need be.
You could also use it to blow foreign objects out of receivers or knife pivots , etc. ;)
Exactly! :thumbup:
Like I said, 6" is just the best for packability and getting things started. For one for use once the fire was actually going pretty good I'd want a 12" one, but that's a little less packable unless it goes in a main compartment or something. Might offer those too, though.
I like the idea of a telescoping type so you get the packability, with the ease of a longer tube, with the effect of a smaller hole at the one end.
