oldschool45
- Oct 15, 2007
Finally finished my first 3 knives. The wharnies are 3/16th 1095 and the boning/filet knife is 1/16th 1095 as is the one I broke to test the hardness. They were stock removal & shaped with just about everything; 4 belt sander, 1 Harbor freight sander, files, hacksaw, dremel tool, drum sender and angle grinder. Heat treat was wood fire assisted by a gas lawn blower using a visual color scale for a 5 minute soak and quenched in McMaster Carr 11 second quenching oil heated to around 150F. Tempering was done in the house oven between 2 aluminum ¼ sheet pans to help stabilize the ovens natural cycle around 375F for 2 hour and a half cycles. The wood is all dymondwood, 1/16Th pins up front, hidden ¼ pin about mid section and the thong tubes are the same ¼ brass rod that I made into thong tube with a drill press and I used Loctite 5 minute epoxy. They aint perfect but they are users. I just want to thank Jason Carter for the moral support and Kevin for the stickies with all the info.
Leather is mine too.
