- Feb 16, 2002
ARGGGGGGGHHH!!!!IT CRACKED
I cleaned up the hammer marks,profiled the blade,swiss cheesed the handle to make it blade heavy,applied funace cement for a wavy temperline.
I heated my quenching oil(vegetable) to 120 degrees,heated the blade to non-magnetic,then quenched it.It came out of the quench fine,I took the blade into the shop and with a 320 grit belt I began to knock off the last bit of clay and make a shiny spot to judge the surface color when it`s in the oven being tempered.Suddenly,over the whir of the grinder,I heard it,..."TINK!" It cracked right in front of me,from the edge halfway up to the spine,right in the middle of the blade.
What happened????????
The only thing I can figure is that instead of monkeying with it in it`s fully hardened state,I should have taken it directly to the kitchen oven,tempered it and then started to clean it up.
Any idea`s as to how I can avoid this in the future??
P.S. I had previously posted on this forum under the name "XxBossmanxX" from now on I will use my real name,
Thanx in advance for any help you can give me,
Scott Fulford
Scott Fulford
