LMT66
- Jun 18, 2008
I ordered some red liner material and got a couple tube flaring tools from a forumite to fatten up my SJ LE and install a set of snake slabs I have from a donor knife.
The liner material is easy to cut to the handle shape but i screwed up drilling the holes in it for the tubes. They were off center just slightly leaving it slightly under on the spine and over on the belly. I'm going to trace out a couple more and do it right.
The tubes were easy to flare but one split (sterile side/middle/seen in last 2 snake pictures) on one side due to not centering it. The other two did not quite mate correctly to the scales. Rock solid but not quite right so i'm going to drill out the tubes and do it again.
After doing this, I can't figure out what Busse uses to get the tubes so perfectly seated and flared. Maybe someone has some insight into this.
Also, any pointers before the second attempt would be appreciated.
