Finally got around to hafting my Kelly Flint Edge on a 32" House Handle handle. I used a 4 way rasp and my Mora knife. Lesson learned - don't use the knife again as it can take off some pretty big chunks when you don't want it to. This took a while to do and having done the first I've learned a few things. I probably should have extended the kerf with my saw as the wedge bottomed out quicker than I expected. I also took too much material off around the shoulder and could have benefitted from a wider wedge. All in all though it seems pretty solid. We'll find out in October at the next old mens gathering.
Picture of my "shop" on the back patio. (New work bench is under construction.) I live in Scottsdale, AZ and it was around 103 degrees at noon today.
Getting close to having it seated.
The blade was really uneven so I took the Nicholson to it at 90 degrees to true it up and will sharpen it later. Lots of hardened bit remaining.
Done......
And done.....
And done again. Put some BLO on the handle later in the day.
Thanks to Cooperhill for giving me a few pointers.
Done......
And done.....
