Hello Community,
I'm in the process of building my first 2x72 belt grinder to get into knife making. I'm looking to build the machine based on a video found on youtube from a guy by the name of "Old hickory forge", but I don't have much details on the extension spring he used.
He says the spring is 3.5” x ¾”, but when I go online to shop for springs I see extra details like "Rate (lb/in)", "Initial Tension (lb)" and "Suggested Max Load (lb)". I've seen and read in different forums that people use some 30 lb compression spring, but does it matter if I use an extension spring for the pivot arm instead?
Aside from the Length and spring diameter, what other details should I look for when buying an extension spring?
Here's an image for reference of the spring im talking about:
https://imgur.com/a/e1XPigg
