I completed grinding the bevels on my first blades today. I still need to take them up to 400 grit.
These are all ground to 60 grit at 5 degrees using a bubble jig except the one on the right that is ground to 4 degrees and 400 grit.
I got wild on the second and fifth blades(counting from left). They were actually ones I was doing near the end. Both times I was a couple passes from being done and then tried to press hard a get done in one pass and things went wrong. I figure I will leave them for now and get them heat treated and then grind those two to 4 degree angles and it will clean up the mistakes.
I have some layout dye and will put some on and then sand up to 400 and send them off.
I want to thank everyone that has been chiming in on my other threads and answering my million questions. You have given me confidence to try this out, to be relatively successful and to screw up too!
These have turned out better than I expected so far.
... into a white plastic bucket that you will keep under your work bench,,Later as you gain more time on the grinder, those blades you think you screwed up, Will revel another pattern to you and become some of your best! With a little help from you!—————-For de burring before ht, I use a worn 220 belt and round any edges just slightly . Hard right angles and burrs can cause stress risers and crack your blades in HT or later...
