- Mar 19, 1999
I was getting tired of finishing up all the stainless blades I have around the shop, so I decided to start one from scratch today, profiled it, drilled it, ground the bevels, normalized 7 times. Then I got stupid. I have seen a lot of blades with amazing temper lines on them lately, so I decided I was going to try for a really nice one. I decided to quench my 1084 blade in water. I finished it up to 220 grit, and decided to use my regular water bucket that I use for dunking blades in when I am grinding them. It is full of lots of steel and micarta dust, as well as some liquid soap so that nothing floats. I quenched the blade, pulled it out, polished it up real quick with a cork belt, and then as I was letting the oven warm up, I decided to etch it to make sure it hardened properly, I put it in some warm vinegar because I was to lazy to run out to the shop and get the ferric chloride, anyway I waited about 15 minutes, came back and check the blade and there was a big crack in it it started at the edge and then branched out so that it was basically "T" shaped. My question is if I had tempered it sooner is there a chance it wouldn't have cracked? If it didn't crack would there still be a weak spot in the blade at that point after tempering, or would everything be ok after the blade was tempered?
Just thought I would share this with everybody, I have quenched several 1084 blades in oil and never had anything warp or crack or anything. I think I will go back to the oil quench.
P.S. is there any performance advantage to the water quench?
Thanks,
Kyle Fuglesten
Thanks,
Kyle Fuglesten
