Hi! I'm a complete new guy here. Lerked on the forums for about a month before deciding to get in on the fun.
Got my first Emerson -- a Mini CQC 7b.
It's replacing my EDC, a CRKT M-16, 02z (small tanto blade, zytel, AUS-6).
I wanted something short enough to be legally defensible just about anywhere -- I've had my 3.1" CRKT folder challenged several times at the airport (and this was well before 9/11), and I figure, 2.9" should be just fine (sigh, not anymore.) And excuses aside, I really liked the Emerson.
It's really quite a beaut. Doesn't look like much, but when you get down to the nitty-gritty, the build is all business, no show.
She cuts cardboard funny -- it tends to curve toward the flat side (opposite the grind) as she goes down. I guess this is because of the chisel grind? I know, I should've gotten the spear-point "A", but honestly, I like the look of this one better, I don't do a lot of utility work, and I've had clip point tips break off sometimes just doing regular work (albeit, not on 154CM.)
The liner-lock feels a LOT better than the one on my CRKT M-16. For one, the lock is a lot more secure feeling. Second, it locks in the same place whether I nudge it into place, or snap it open. (The M-16 had the odd habit of locking around the center when snapped open, making it REALLY hard to shut.) Last, the Emerson actually has a ball and detent, unlike the M16, which means that it will stay shut (surprise.)
I had to do the "rapping the spine on the table" trick to get the liner-lock fully settled in -- before the lock was engaging only on the tiniest edge of the shank (tang?) Much thanks to the Usual Suspects. Now it's engaging all the way, every time, all the time, and always in the same place.
I have a few questions, though.
There's a number on the blade: 056. Is this a serial number? I guess it's not a model number? Could this really be made so early? Maybe no one's buying the Mini's. I don't see anyone talking about them here.
The black teflon looks like it's already coming off the blade in one place... odd. Doesn't really bother me much, but they should just license the Glock Tenifer or H&K black coating. Those are mighty durable.
One problem -- she doesn't feel all that sharp so far. At least she won't push-cut paper and cardboard as easily as the CRKT. Does she generally need some extra touching-up from the factory? How do I sharpen it? All I have is one of those silly sharpmaker with the crossed ceramic rods. Will this be sufficient? The angle isn't standard, so what kind of sharpener do you recommend?
Is it better to get a diamond rod and a magic marker and learn it that way?
Also, it looks like the tip is rubbing against the liner when it's closed. At the pivot, it looks centered, but somehow the flat side of the tip is just barely touching that side of the liner.
What should I use to oil it? Light (like WD40), or heavier lubricants (like gun oil)
Thanks!
-Jon
Thanks!
-Jon
