I got bored and realzed that the trox drivers I got to assemble my Typhoon are exaclty what I needed to dissasemble and cleaned my CRKT BladeLock. It's the frist time I had disassembled one of my knives and it went a lot smoother than I feared. If someone could look over what I did and warn me if I left anything out I appreciate it.
I just wiped the dirt out with a paper towel and a q-tip (dry, no solvents). I reassembled everything with some medium thread locker and I put a drop of 3-in-1 on the bushings on each side of the blade and another drop on the thumbstud when it was all back together. I adjusted the pivot screw (right term??) by tightening it all the way down and then backing it off in 1/4 turn increments until the blade moved to my liking. There is no side to side play in the blade. The handles also had a little bit of slop in them, so I tightened all the frame screws down tight.
Did I forget anything? Should I take it apart again and do something else to keep enjoying this knife??
