- Jan 2, 2010
I have been putting my shop together for about the last 1 1/2 years and have finally made it to my first heat treat.
Actually I have only ground 3 blades so far. The first one I didn't want to screw up with my first attempt at a heat treat so that one is next. This one is currently in the kitchen oven for its first temper. I wanted to test a piece of unground steel out to see if I could get it to harden properly. That turned into just profiling it, then grinding just a little of a bevel, then what the heck i'll just make another knife.
All I have used so far is some 1080 from Kelly Cupples. The heat treated one is 1/8" thick with a less than full flat grind, ground on a 2hp GIB with variable speed. I have an Evenheat with a perfect fire controller. I made a little baffle of stainless foil around my rack in the kiln because of the discussion of not having recessed coils. I set the oven for 1475. After it was heated up I put the blade in for approx 8 min. Then into some McMaster-Carr 11 sec oil heated to 130 degrees. Everything went as smooth as I could have imagined. Very little smoke, no flare up, blade came out with little to no scale, no warpage or cracks (WOOHOO!) which was my biggest worry. Now it is in the kitchen oven for a 2 hour temper at 425.
I have not done a file test yet. I'm a little worried that it didn't get up to temp after being in there for 8 min. I only took about 7-10 minutes from post quench the oven because I cleaned it up a little and washed the oil off. If anyone has ANY feedback I would love to hear it. Or any future suggestions as well.
Here are some pictures. First is the quenched one, then the other ground ones and some other profiles
