- Jan 20, 2002
Hi everybody !
I work on my first hiddent tang knife. I make the hollow grinding this afternoon and I am verry happy with the result. (it is the first time that I am happy and not too frustrated after a grinding session... )
I would like to have your opinion and your help on some questions:
1 - When I started, I thought to make my hollow grinding wider.. (see the paper model on the picture, I have 5/8 wide instead of 3/4 or 7/8 as I wanted ) What do you think ? I have stopped there for now. I wonder whether I must widen it more? A large and eavy knife (12") would have advantage has a less wide grind (it would be less fragile?)
2 - I read many times that it was a nonsense to make narrow tang knives without making selective heat treat... My knife is in 440c and I will make the treat treat by a company... Is this quite serious if the blade have the same hardness always on the blade? Can I soften the tang with a small propane torch after the heat treat? (I can make this with carbon steel, but for stainless? Do I have to heat the tang until it become blue? Is it possible with propane torch ?)
3- I wanted to make my guard immediately, but I thought that I would have to clean and put the final finish one the blade after the heat treat. If the guard have a good fit (press fit) before the heat treat, there are chances that it is loose after the final finish ? But... If I make the gard after, I will not be able to modify and correct the shoulder of the tang with files...
Before or after ???
Thanks for your hel guys !
Alain M-D
Before or after ???
Alain M-D
