I had more than 10 year pause in my knifemaking. A month or so ago I decided to start it over again. So I did. I bought a pile of tools, steel, wood and almost everything. I made two blades from A2. For one I even made handle, and all hardware. The only remaining thing was to HT it and finish. I decided to HT it myself as I did years before. I read all datasheet, all insrtuctions. Today I've made an improvized foge and fired it.
Everything was almost perfect. I heated blade to 1400F, than soack for 7-8 minutes and quenched in a front of a fan. Not very strong but big fan, so air flow was pretty even. Checked the hardness - file slides. Ok placed the blade in the oven set it to 500F. Almost 4 hours in the oven. Than slowly cool down. Everything looks great. File still slides, but not that easy. I estimate it ~60.
Anyway, cleaned it up a little and decided to check how it is tough. Tip in to the vise, halfway down. And I pilled the tang....I've got somw juce in my hands. The blade bend like a spring a bit and snapped.
My first blade in 10 years snapped....
Ok, I got some beer and begun investigation. The breackpoint is smooth and grain is even. Pretty fine grain. So I did not overheat it. And than I mentioned colorized corner. Checked the other half - the same pattern. Washed it carefully - still remains. My conclusionn - it is CRACK! And it was there BEFORE HT!!! Because it is oxidized. So my blade snapped where it was a crack. The question is where it came from????????
I've got the A2 steel from McMaster. It was annealed 1/4" X 1 1/2"X36" ground bar. I did not bind it or cold forge. Just cut with the hacksaw to the shape and removed metal to form the edge. Flat ground. One side 1/4" other 1/16(edge). I did not do anything to make this crack.
But it is there.
Now I do not want to TH second one I want to understand WHERE for a Gods sake I made a mistake????
I'll try to attach the picture:http://club.foto.ru/gallery/photos/photo.php?photo_id=666344
