First Impressions : Case Wharncliffe Copperlock Silver Script
Revolvergeek
My Case Wharncliffe Copperlock Silver Script arrived Tuesday. I Had to have one of these when I first laid eyes on it. The blade is long and thin and very pointy, which I like very much. The knife has a nice heft to it, the handle is long enough for all my fingers to have a place to sit but yet slim and easily forgotten when dropped into a back pocket next to my notebook or wallet. The front bolster provides a good feeling of security from the edge without being too bulky or ruining the lines of the knife
The blade opens smoothly, but the lock takes a pretty good bit of pressure to release. Never having played with another Copperlock, I don't know if this is typical for this design or if mine is just a bit stiff. There is not play whatsoever in the lock when the knife is open.
The blade is perfectly ground, but came with a very coarse edge on it that would not push cut anything but pulled through cardboard pretty well. A few minutes of work with a DMT fine hone brought a nice shaving edge to it. I suspect this thing would cut like a scalpel if I really worked over the edge, but it has been a busy week and I have not had time. The blade has a nice distal taper to it and is very thin at the tip, which I like on a knife like this, but it would not be the knife to pull staples.
The overall fit and finish of the knife does Case proud. No gaps in the liners, everything is smooth and polished and not a sharp or rough spot anywhere except on the blade. The handles are a nice burgundy color and fit tightly with no gaps or any flaws that I can see. The only potential problem that I can see for this knife is that the front portion of the blade does not sit very deeply down into the handle when closed, so if sharpened a lot with coarse stones I could see how blade wear could present a problem with years of hard use.
