I recently picked up a Cold Steel Spartan for $60 on Amazon. I've had it about a week and I love the thing.
Here's a little information on the blade and shape, and the history of the design.
The Spartan is an Andrew Demko-designed knife, using Cold Steel's Tri-Ad locking mechanism. Needless to say, the lockup is as amazing as the look in the mugger's face inevitably would be when you procure this at his demand of cash.
The blade shape is a Kopis design based on the (Surprise!) Kopis sword used by the Spartans. It will cut everything. I guarantee you. If you compress three inches of cardboard together, sharpen this thing up, and slice, you will halve that cardboard instantly. It is an amazing knife. Stabbing is very effective too.
The knife's Grivory handle also comes from the Kopis sword, and your hand really locks into it. This makes gimping unnecessary, because you get such amazing grip already.
The 4.5" AUS 8A blade arrived razor sharp, props to Cold Steel on that. It is bead-blasted and looks really cool.
It has ambidextrous pocket clips included, good for a southpaw like me.
Torx-head bits will disassemble the entire blade and adjust the tension to allow easier opening of the blade.
The blade has a little hook-type thing instead of a thumb stud to open the blade, just hook that on the seam of your pants pocket and pull as you take out the blade. It will snap open as you pull. If the pull doesn't fully open and lock the blade, you can simply flick your wrist to deploy fully.
There is a lanyard hole already drilled in.
As good as this blade is, there are a few issues I have with it currently:
1.) It weighs a crap ton. Once you're cutting stuff, you'll enjoy those nine ounces, but right up until then, you'll hate them. Really, Cold Steel, lighten the liners and the Tri-Ad locking mechanism a bit! You can machine that out some and lose none of the strength you had. For EDC this may be an issue. As an emergency tactical blade, or a primary hiking blade, this thing is much better suited.
2.) in the week and a half of carry, I have noticed a few little rust specks on the blade. That is just the nature of the AUS 8A, I'd assume.
All in all, though, this is an excellent tactical folder (and EDC blade, of you don't mind weight) for the price, especially considering that the 4.5" blade has many fixed-blade capabilities in a much more compact size. I'm going to say 8.5 of 10.
