First knife and first post.
Been lurking for a little while now soaking up information. Recently completed my first knife. Of course i decided to go big or go home and make a general purpose kitchen knife for use here at home.
Started with precision ground 3/16" O1.
Cut out the profile with a hack saw and refined the profile on my bench grinder. Further refined the profile by draw filing as the bench grinder had left a slight bevel.
After everything was flat I hand ground the bevels using a Gough jig i cobbled together. This part took forever. Doing a full flat grind with a file was not a minor undertaking.
Did all the normal hand sanding and actually went all the way to 800grit prior to heat treat.
Made a small forge out of firebrick and a homemade reil type burner heated to non magnetic and quenched in canola oil. 2 temper cycles at 400 degrees and then back to hand sanding.
I also blended the plunge line. They are actually right in front of the handle.
If I had to do it over I would have had a little more distal taper and would not have used stock this thick.
Handle is plain Jane mahogany I had laying around and some 1/4" stainless rod i picked up.
Between finishing the blade and gluing up the handle I received a Grizzly belt grinder as a gift. So the handle was shaped on the grinder. Very obviously I overheated the handle pins causing the wood to burn and more than likely compromising the epoxy bond. Oh well lessons learned (lots of em on this first build). I sharpened it up to a wire edge with a well worn 120 grit belt and then refined the edge on a lansky sharpener. Sharpened to a 20 degree angle.
Not the prettiest but it cuts everything like butter. So far I am pleased as the knife is for me and is useful. Of course I have been bitten by the bug and I am practicing hand grinding on the Grizzly with cheaper 1095. No the prettiest plunges but they are functional. I may share those later.
This one is prior to sharpening.
Nice looking knife and a great effort. Sounds like you learned a lot of valuable lessons. For kitchen knives go very thin with the edges. If you look at the third picture, it shows that your edge is very thick. You already know you started with stock that was way thicker than you need. But if you think your knife cuts well now just wait until you make the next one with a much thinner edge. Your knife will be great for the tough chopping jobs.
