- Dec 8, 2003
I'm almost done with my first knife (a 5" cleaver from 01 tool steel), all that remains is the handle, some finish sanding, and sharpening. Sunday night I ordered some black micarta, epoxy, blind bolts, and cutler's rivets from K&G. Due to a goof on my part while roughing out the initial pattern the tang will have to be hidden, since it's too narrow to cut the scales the same width and still have a meaty enough handle. Once my micarta arrives I plan to cut a relief into both of the scales with an end mill and glue them together around the tang with epoxy. This leaves me with 2 questions:
1 - Is epoxy alone strong enough to hold without bolts or rivets? The end of the tang is shaped with a triangular projection, so there should be no danger of sliding out of the handle if the tang fails to adhere fully to the scales. (If my description is inadequate I can post a photo when I get home tonight.)
2 - The blade is hardened to 59 Rc. Will I need to torch the tang if I need to drill it for bolts or rivets? Also, would it be a good idea to anneal the tang and upper half of the cleaver to soften the shock that's transmitted to the user?
Shalom,
Mark
Shalom,
Mark
