- Jan 24, 2021
I'm attempting my first blade ever, a 9" kukri out of 5160, and and I have more questions than I can find answers to. I built a forge out of a 20# Propane tank lined with 2 inches of ceramic wool. It has a single burner in the center at about a 30 degree angle. I drilled a hole for a thermocouple and can keep temps inside fairly steady by finding the sweet spot between the choke, pressure regulator, and the valve. I blocked the opening with fire bricks, leaving a slot for me to pass the blade through. When the tip hits the back of the forge, there is about an inch of the tang hanging out, which is enough for me to grab with a pair of vice grips.
The problem I'm having is the first half of the blade heats to nonmagnetic, but the back end and the ricasso is a dull red and stays magnetic. I'm moving the blade lengthwise as much as I can while still keeping it in the forge and rotating it often. I figured if I could hold the temperature close to 1525, I could just keep it in there until it was heated evenly, but after 20 minutes I was still magnetic at the ricasso end of the blade. I don't know if I should crank the heat higher and keep cooking the front half until the back end catches up, or if I need a deeper forge, or maybe cut an opening in the back end to let heat escape from that end also and be able to pass the tip through that opening to get the ricasso end deeper into the forge.
I'm also having a hard time finding info on how long should the quench be taking. I need to get the temperature below a certain point, but how low should it be? Should I leave it in the oil until it is cool enough to touch? If the oil is at 130 degrees, does it balance out in temperature after the hot steel is submerged, as long as I have a sufficient amount of oil? I also read that after quenching I should grind off the scale before tempering in order to be able to see the colors on the steel, but most of what I read focuses on time and temperature, not on color.
So, such are my struggles, which I haven't quite been able to find the answers to online.
Thanks!
Thanks!
