- Feb 25, 2016
All I have started a sketch and made a cutout of a knife. Please feel free to critique.
Given the profile of the handle, i.e., the deeper curves, it seems like it would be a little short to fit large hands comfortably. How does the cardboard cut out feel?
Take out most of that palm swell belly in the handle bottom ( at least half of it) and make the handle 3/4" to 1" longer. 4-4.5" works well. The butt doesn't need such a big round end either. Just let it trail off from the bottom and top into a very simple bird's head style.
Your knife has a piercing shape and function, so the handle needs to be large enough for a full grip. The last thing you want is a weak grip on something you are stabbing/poking with ( even if you never stab at anything, it should be capable of doing it safely).
Your blade size and shape is basically OK, but the grind lines will be very difficult to nearly impossible to form. The slanted plunge line is fine, but the yokote ( line separating the main bevel from the tip bevel) and the shinogi ( ridge line between the main bevel and the upper part of the side) along the kissaki ( tip end) will be hard to do with the angle drawn. I would change the yokote to a vertical line at 90° to the main shinogi. Even then, getting a crisp kissaki on a first knife is going to be hard. Another problem with your kissaki is that the thin and pointed tip formed by the angle drawn from the mune (spine) to the tip will be very weak and prone to snapping off. The whole point ( pun intended) of a tanto tip is a strong and tick tip for piercing.
If you are set on trying a tanto blade, then:
1) Change the mune (spine) to a straight line to the tip
2) Make the kissaki-shinogi (the grind line along the tip edge) parallel to the angle of the tip
3) Don't make the kissaki ( tip bevel) as wide as drawn. It should be a bit narrower than the main bevel for strength. The less wide, the thicker ( and stronger) the tip. The kissaki has a piercing function, not a cutting function.
4) Make the yokote ( the line where the main bevel and the tip bevel meet) a vertical line
Suggestion - Possibly consider just having a normal drop point style blade and grind line on this knife and try the more complex tanto tip on a future blade.
I like the bottom one a lot better, but personally, I'd lengthen the blade just a bit more to make the look a little more proportional. As it sits, the blade looks a little short.
