So, this started back in October. I was looking to replace my current camp knife for a December river trip. I went from not being able to finding one I quite liked to thinking about making one from a kit, to deciding on going from scratch. I wound up wildly overshooting my estimate. Start to finish took three months and one day.
I wasn't counting on the high value of mistakes as part of the learning curve here and ended up starting over a couple times and redoing things a couple more. This is the third piece of steel I worked. The first two were 1095, but I scrapped that in favor of 0-1. My mom is a glass maker so I have access to a kiln and could use regular oil for quenching.
Anyway, I got a lot out of the WIP threads while I was working on this, so I thought I'd post pictures of the whole process. Picture quality isn't great, but hopefully someone will find some of this helpful.
Here's the stock. 0-1 from Jantz, 3/16" thick, 2" wide:
I wanted to use all hand tools on this first one to get a feel for how things worked. I'm in a small apartment, so I used a portable workbench with vise I build a while back. I'm using a high-tension hacksaw for the rough cuts. Cutting was a lot easier than I was expecting.
All the saw cuts done. Couldn't resist this shot.
I used hand files to finish the blank. For the edges, I made a sanding stick to keep things square. On the handle curves, I did the same, but with the paper wrapped around a drumstick (okay, it was a Rock Band drumstick).
The blank all finished. This pictures is dull for some reason. It actually looked very nice. I finished to 400-grit.
For the plunge, I used a small round file and worked very, very slowly. I really screwed this up on the first 1095 piece, so I wanted to be careful.
One of the longest parts was filing the bevels. I used a 12" mill bastard to draw file. Took forever, but did a pretty nice job. I marked it with a sharpie a bunch to make sure I was taking metal off where I thought I was.
Holes drilled for the pins and a few extra for glue rivets. I actually wound up using electricity here. I couldn't find a hand drill locally and figured drilling holes isn't exactly something I have to learn from the ground up. All ready for heating treating.
