Yep get er right and leave er be. At first you may always want to do a practice run of scrap just the same as your project. #277 might be a bit heavy for most of your projects. It would be for me. I run 202 top and bottom. That takes care of 99 percent of the things I sew on my machine. If I need lighter (leggings, linings etc) I'll use Nichole's Cobra 18 thats set up 138 top and bottom. One thing I do and Nichole does on her machine too is change needle size for the project. This will adjust your tension for the project too. So for instance I have a size 25 in most of the time. This takes care of sheaths, holsters, rifle scabbards etc. If I'm sewing one piece of veg tan to a lighter piece of chap leather such as in a pair of chinks or chap tops, then I'l drop down to a 24. If I'm sewing real thick such as the d rings on a martingale (3 layers of 10-12 oz), I'll use a 26. No thread change or tension adjustment from 7-8oz total thickness of project up to 36 oz or better. This is what works for me. Nichole does the same on her Cobra 18. She always runs 138 top and bottom and then changes needles between 20 and 22 depending on the project. Hope this helps ya some.
