- Apr 23, 2011
Hey guys, this is my first post with some pictures of my first knife that I'm working on. I was hoping for some feedback, I'm sure there will be plenty. To be honest, I'm not very handy or mechanically inclined so I knew it would be a stretch to make anything halfway decent. I have looked over a few knife making books- Goddards $50 and Blades Guide to Making Knives. I felt a bit lost in both of them though. Most of my ideas of what is correct came from the website absolute cheapskates guide to making a $30 knife. I've looked through a few forums also and that has helped a bit. I did get a bit impatient and hurried to much.
The knife is made of 1095 steel that I ordered from Jantz. It is 1/8x 1 1/2 I think. I don't have the specs in front of me atm but I'm pretty certain that's what it is. As far as tools go, I borrowed an old electric drill, a 10inch Nicholson bastard mill file, 120/220 sqaures of sandpaper, and some c-clamps and a vise.
I drew the pattern on paper and then cut it out and traced it on the steel. It's gone through some revisions
I wanted a knife with a 3 inch blade that would be easy to flat grind with a file. I also wanted a finger groove on the backside of the blade for more security when holding it in a reverse ice pick grip. This 2nd finger groove on the back turns out to be an unneccesary idea in my mind I think. I wanted a sharp angle on the end of the grip for busting windshields/etc. I decided rather than put grips on it I would cord wrap it. We'll see how that goes since I forgot to check and don't know what kind of grip styles you can cord wrap.
There is a ridge on the top of the knife about where the handle and blade meet that I didn't get filed down enough.
Things I don't know about.
- I don't know exactly how much of an edge to put on it before it gets heat treated.
- I'm not sure if my flat grind is flat enough or if I need to take more in the middle of the blade?
- Should I have drilled the holes in the handle in different areas? Should there be more holes?
- Once it's heat treated it's too late to fix anything grinding wise right?
- When I'm filing, should I always draw across the blade at a 90 degree angle or can I hold the file at a 90 degree angle and pull the it down the blade. This second method seemed to work to pull off the high areas in the middle of the blade that were a result of uneven filing.
I mainly want a strong blade that will be sharp. It doesn't have to be perfect but I want to learn what would have made it better.
Please comment and critique as much as possible.
(I can't figure out how to post a picture so I'll go search that and put the pics in the next post)
