- Feb 4, 2006
Just received my first Spyderco Paramilitary and some bandaids from New Graham (it was also my first time purchasing from them). At first, Spyderco's didn't appeal to me aesthetically, but they kind of grow on you.
Let's first have a gander:
Compression lock:
Comparison shots:
I kindly emailed New Graham and asked that they check the knife out before sending it to me and they happily agreed to my terms
Fit and Finish:
The blade is well centered (not perfect, but good enough to pass my picky tastes), locks up solid and opens easily. Not the smoothest opening knife, but that's ok. The fit and finish are very good, on par with all my other knives. The handle scales are even and nicely put together. The factory sharpening is sharp. Much sharper than my Benchmade, sharper than the SERE and about the same as the Rat Trap (though I'd give the Trap the nod). One little problem is that the blade seems to rub very lightly against the G10 at the ricasso when I open the knife. I hope this doesn't cause any long term problems, would this be something I might want to fix with a little sandpaper?
Feel:
The knife is light. Feels a little lighter than the Rat Trap in my hand. It is also quite thin, slightly thinner than the BM710 and a little thicker than the Trap. I wasn't sure I'd like the finger choil much, but after holding it a bit it feels comfortable. My hands are small-medium so not using the choil is also quite comfortable, though I can see how that bump behind the choil can be a little annoying. The round thumb hole is very simple to use and I can already say I prefer it to thumb studs after just a few hours fondling it. The G10 is rough and grippy, moreso than my Rat Trap which was the grippiest of my knives before this purchase. The pocket clip is a little tight, and combined with the rough G10, I can see this quickly wearing out my pants. Any way to loosen it a little?
The Blade:
The blade stock is almost 4mm thick at the ricasso, but tapers off quickly to a thin, delicate looking point. The wide blade and full flat grind also leave the edge quite thin. As I said before, it is very sharp and easily push cuts paper. It doesn't shave hair quite as well as the Rat Trap, though. At first I thought I wouldn't like the blade:handle ratio, but after handling it, it doesn't bother me a bit.
I also thought the marking on the tang was a humorous touch:
Golden, Colorado
U.S.A. Earth
The Lock:
The compression lock seems to be a love it or hate it deal. Personally, I very much enjoy it. Like the axis lock, it took a few minutes to get used to, but is a cinch to operate and locks up nicely. Also like the axis, it can be pulled back, allowing you to flick the blade open and closed. The axis is much smoother, but mentally the compression feels safer. No clue how they actually compare in strength though. I haven't had the best experience with liner locks (the SERE in particular), so there is no comparison between those two, personally.
The lockbar just fully makes it onto the tang, leaving plenty of room to wear. After hearing about some issues with the lock, I asked that the guys at New Graham check it to make sure it locked solid and with room to wear. They did a great job :thumbup:
Overall, I love it and am very pleased with the purchase. This one will definitely see a lot of pocket time. I can't really find anything wrong with the design aside from the blade rubbing and tight clip/rough G10 combination.
Just one little question I have for Sal or any other experienced Spyderco lover: What is this little dark spot on the lockface of the blade?
Is that a spot left by a Rockwell test or something? My main concern is that it could be corrosion, though I doubt it is. Is this a common thing to see on Paramilitaries? It doesn't rub off, and it looks like a little dark dent (as you can see).
Thanks for reading and thank you Spyderco for this gorgeous little knife!
-Jon
Compression lock:
Comparison shots:
Fit and Finish:
Feel:
The Blade:
Golden, Colorado
U.S.A. Earth
The Lock:
-Jon
