Yes! Sort of... I finally decided enough was enough and heat treated my knife which I had been working on since January
It is made of 1095 steel. I built a charcoal forge lined with ash. It has an in-line tuyere like the one made by Tim Lively which is fed by a hand crank blower. I got a good bed of charcoal and I placed the knife blade down in the fire. I started cranking until the knife got a nice deep red. When I got the color I wanted, I started my timer, pre-set to 4:30 for the soak time, and put a hot piece of mild steel and dropped it into a jar of canola oil I was using for quenchant. When the timer rang, I quenched the knife in the oil and agitated until it was cool enough to touch. After checking for hardness with a file, I tempered in the coals by checking the color of the oxides. Then I let the knife soak overnight in white vinegar to get rid of the scale. This morning I cleaned the knife off a bit a wire brush and sandpaper. What I saw under the scale was this...
Is this normal? Will filing off these imperfections ruin the knife since 1095 is shallow hardening?
Thanks for the help guys
EDIT: pictures added
