Hello, this is Hammerdownnow. I had some problems with my subsription and desided to start fresh with my real name.I see where I screwed up my terms. Not really wind resistance, I meant air resistance. If you take a flat board and swing it sideways with the broad side pushing against the air you will feel resistance. Turn it on its edge and swing it, it will "slice" thru the air with much less resistance. To illustrate, if you take an oak board and throw it, like a knife it will tumble and twist and evenually run out of steam and fall to the ground. If you take a balsa wood board and do the same thing it will go a couple feet, lose steam, cut weird didos, float and flutter to the ground. Or, think baseball vrs whiffle ball. Knives are affected by this to a much greater degree than you might think. When a knife flys thu the air, it twists and tumbles alternating sliceing and pushing air. Too light a knife magnifies the affect of the "Butterfy Effect". How light is too light? I am not sure.
I have not experimented with what would be the minimum weight to use to negate the phenom, but only go by the recomendations what has been written on the subject by experts like Charles McEvoy. And by memory of what I have read and personal experience. I guess I could look it up, but I am pretty sure 1lb. is standard.
Some beginners lose interest by starting out with to light and to short knives. Knife throwing is a complex hand, eye cooordination, learned skill, dependant on repeatable and predictable motions. The less revolutions one has to keep track in ones head, the shorter the learning curve. Couple a short knife, 4"-6" with to light of weight leads to frustration. If the floating effect was more predictable it might be easier to control. These are beginner problems and an expert can throw about any size or weight by making allowances that only practice can teach. Now I am starting to ramble. thanks again for allowing me to muse. :thumbup:
