First time carbon steel knife user
Recently I purchased this lovely carbon steel knife (picture below). I am kinda confused in how to properly take care of this knife since he left it partially done. Which I like a lot because I can see the hammer strikes and all that. Is there a different way I need to take care of this knife or will just wipe clean and light use of mineral oil be fine? Also I have never owned a knife with a wooden handle. Is there a type of wood cleaner I should get? Thanks for all your advice in advance.
Same as a cast iron skillet. Needs to be "seasoned". A lot of folks just use whatever gun oil is available. I use renaissance micro crystalline wax. You should also dedicate a drawer or a spot to keep it and other knives out of its sheath to prevent damage from humidity.
I would highly recommend hot waxing the sheath, or getting/making another sheath and hot waxing it. The difference in corrosion protection vs an unwaxed sheath is night and day. Many of my EDC knives are carbon, worn IWB Summer and Winter. Prior to using a wax treatment they required daily wipe-downs and still would rust a bit, now they are as maintenance free as stainless as long as I wipe them down before sheathing. If an occasional user, just store them somewhere with low humidity.
Carbon will patina from most every thing it contacts. Onions, meat, soil and the like. You can let it go, just wiping the blade down after use or the blade can be kept clean using Magic Cloth or a similar product.
As a knife maker, I prefer carbon blades they grind easier; as a knife user I like the way carbon sharpens.
Enjoy your new blade, Fred
Alright thanks guys. I am going to go look for some wax in my area. Will that renaissance wax be fine with blood or should I look for a different brand or just any type of wax?
If you're going to wax it, do a search on this site and a general web search - will give many ideas for how to safely apply it. I've just used the regular Gulf wax for canning - is simple paraffin.
Briwax is one of the best. Moisture will not penetrate it.
Eight and a half months ago, I was gifted this Northwoods stockman with carbon blades. In the time I've had it, it has been used a fishing knife, including time spent down on the Chesapeake Bay which is a salt water environment. It's been carried as my EDC pocket knife, sliced fruit, cut down cardboard boxes, and has been rinsed off in a creek when camping.
The only real care it gets is being wiped down with a dry bandana after use. Once in a while I smear some Chapstick around on the blade for time when we were kayaking and it was a wet trip. It survived b ring in the pocket of my wet shorts for the duration of the trip just fine. The blades have darkened, but thats normal for a carbon bladed knife. It's called patina, and it actually helps protect the blade. I would not store the knife in a sheath, that will do more harm to the blade than water. The acids in the leather will rust a knife.
Contrary to what some people believe, carbon steel is not going to rust away on you with just a tiny tad of care. Just use the heck out of it. The Vikings crossed the Atlantic ocean in open boats and the Roman legionaries marched all over the known world in all kinds of weather. They managed to keep their carbon blades from rusting under much more primitive conditions that we live in now in the 21st century. JUst use it, don't worry. Just smear some Chapstick on it when you wipe it down with w dry cloth.
As for the wood, a little linseed oil, or mineral oil, or furniture oil of some eking will be fine. A little on a cloth and rub down for a bit. I've used linseed on the stockman scales, and they've held up fine, even to salt water and fish guts.
