Hello folks! I posted this on Reddit a couple of days ago and basically only got a handful of replies that told me to "send it in to someone" to have this part done. Basically, that wasn't helpful at all. If I can't do the most important part myself, I may as well not bother at all with this project. Anyways. Before the original post continues below, I'll give you a quick summary.... I work at a foundry, we have two huge ovens which are typically run at 1010°, 1020° or 1050° C. Sometimes higher when we pre-heat the ovens before putting in something large, the temp usually drops a lot when cold material is inserted. (In our case, suction roll jackets for the paper industry, from small to 60+ ton chunky bois) can piggyback on these whenever I want really, I just need to figure out if heat treating a knife at work is viable at all.
Original post:
So I've decided to make my own knife. I have bought all the materials needed and also have most of the tools I need, but the main problem is how to get the steel heat treated properly. There is a LOT of information out there and it's not always quite clear how it's done properly. Let's ignore everything else and focus on the two pieces of steel I have..
One is an X50crMoV15 stainless, which I believe is similar to what you'll find in many kitchen knives and it should also be reasonably similar to whatever Victorinox uses in their blades. I quickly realized that starting out with stainless was a bit of a mistake, but I mainly went with this because it is heat treated at EXACTLY the temps we typically run our ovens at, at work. I work at a foundry of sorts and we have huge ovens here which I should be able to use for this. I could just chuck the steel in a corner (these are ovens are fairly large, 6x4x2 meters or about 1350 cubic feet. And that's the smaller of the two) and let it sit in there for the required time. However, finding aluminum blocks to plate quench this thing properly is very difficult and expensive in Sweden. The website mentions this can be quenched in oil too, so maybe it's not all lost.
The other is a 1075 carbon steel, which is the one I will mainly focus on. Our ovens have sight-holes where I could easily poke the blade into while we are producing something else. I would be sticking these right into air temps of roughly 1050° C or 1922F. And I'd be keeping some warmed up oil on standby next to me. I intend to do a rough finish of the shape of the blade before this. But here is where things get a bit confusing...
After roughly finishing the blade, am I supposed to "normalize" it three times before the actual heat-treat plus quench? I.e. heat to non-magnetic, let it air cool, do this 3 times. Then heat to non-magnetic, let it go a shade or two past this, then quench in oil with a back and forth motion? Then check if a file skates across the blade or still takes off material. Another problem I have is that the workplace does not have a regular kitchen oven, is this where I can do a "snap temper" to at least prevent the blade from cracking, until I get home and temper it in my own oven? (Which would be several hours later, possibly the next morning) And if so, how is this done?
Original post:
