- Nov 11, 2014
I recently purchased my first knife "kit" and am trying to get everything in order before starting.
There is a slight gap between the blade and the slotted guard. It seems like a closer fit at the bottom and opens up toward the top, about 1/32 inch. Is this ok? Should I try to narrow the gap for a tighter fit at the top?
I was planning on soldering the brass guard. I'm not sure how to hold the guard onto the blade during the soldering process without using some sort of clamp over the guard (clamping it to the blade) or under the guard just to hold it up. Either way gives me a concern about interfering with the soldering process. Perhaps purchasing a Kant twist clamp? I only found one post about holding a guard on using plumbers putty but that sounds unfriendly to the lungs.
My other concern about the guard is there is no notch at the bottom of the blade for the guard to fit up in to. In my searching of several sites it seems every person fitting a u-shaped guard has some sort of notch. There is nothing in the instructions for this. My apologies for not using the proper terminology yet...still learning!
I don't think I can post a photo with my current subscription.
Thanks! Chad
Thanks! Chad
