I have to say I am really impressed with this knife. But I ordered a flipper version because I expect to flip it... Will it eventually break in? Or do I have to make my detent bigger myself?
When I adjust it at the pivot is ok to just use a flat head screw driver or coin?
I have the same detent problem. Just give it a little wrist flip. That's about all you can do to it. I have pretty much just learned to live with it.
thanks man, yea with a small adjustment and some lube this knife is deploying incredibly smooth.
Wrist filliping isn't required regardless of detent, technique is the key, if I can flip open my 3" XM, anyone should be able to flip open any size XM.
Bad detent will lead to the need to have the a wrist flick. I have a Southard flipper and had a ZT0560; they both flip better than my XM-18. I can just press down on the flipper and the blade would deploy perfectly and doing that consistently. My girlfriend's crappy Chinese Gerber flipper flips well and consistently because it has a strong detent. Whereas with my XM-18, if I don't push it the right way, it won't swing all the way. Oil and loosening the pivot helps, but doesn't guarantee a consistent deployment. The only time that I do get consistent flipping is with a wrist flick or some sort of extra motion to let the inertia of the blade to swing into locking position.
It doesn't appear you are hearing me. A strong detent allows any newb to flip a knife with no technique whatsoever. But, technique overcomes any detent (even if a knife had no detent), you don't have to use wrist action unless you have poor technique. If I can do it without wrist action, anyone can.
I heard you. We are discussing technique and detent. I understand that technique can play a role. I can open my XM without a wrist flick if that answers your question if I'm a "newb". When I'm buying a flipper, I'm expecting the flipper to work as a flipper. Only knife that should require techniques to open are balis, but that's beside the point. For a high caliber knife like the Hinderer, I would expect the flipper to deploy perfectly with minimal effort like what I would expect in a Southard Flipper, a ZT0560, or a Shirogorov. I did buy a XM-18 Hinderer Spanto FLIPPER. The common aspect in all those knives is the strong detent. Gen 4 Hinderers have strong detents and they flip better. There are a few comparison videos on youtube about it. If Gen 3 is perfect with the weak detent, then why did Rick go through the trouble and added a stronger detent? You may be uber talented in opening your Hinderer, but I can't say the same for my best friend or girl friend who needs to borrow my knife. What if it's an emergency situation where someone has to borrow my knife and he/she doesn't deploy my knife properly the first time?
But please, let's not discuss this any further. This won't end well. You can stand proud and strong with your technique while I carp at my detent. Do know that I am a proud owner of my XM-18, but I'm not afraid to admit that it's not perfect.
