- May 25, 2011
Fitorch graciously sent me a copy of their MR35 flashlight for evaluation purposes. Other than keeping the flashlight, I am not compensated for my evaluation. My thoughts on the MR35 are exactly the same thoughts I'd express had I purchased the Fitorch MR35. I would like to thank Fitorch for allowing me this opportunity.
With 5 select-able colors of light (white, red, green, blue, ultra-violet) and a maximum output of 1200 lumens, the Fitorch MR35 is marketed with the outdoors person in mind (specifically hunters, campers, hikers and the like) but it has features that will be very appealing to the average user as well.
Fitorch is known for their excellent build quality and the MR35 is no different, from their other models, in that regard. The body features fine circuitous grooves, from the tail cap to the head, that are intersected by perpendicular (deeper) grooves; a combination that gives the user great grip and outstanding comfort. The finish is an anodized semi-gloss black; applied evenly from head to tail (helps prevent scratches and wear).
Both ends of the flashlight are removable (head and tail cap). The threads are square cut and well lubricated (as received).
The tail cap has a U-shaped cut out on the end, for easy access to the tail switch. On the end of the tail cap are two slots that can be used to attach the lanyard. The MR35 is somewhat capable of tail-standing; albeit poorly. On the inside of the tail cap is a stout spring. I'm not sure if it is gold plated, but it is gold in color. The tail switch is covered in a rubber cap and gives excellent feedback when pressed. There is an audible click when fully pressed and released.
The head features deep cooling grooves cut in the base. On one side is the side switch – stainless steel, with a surrounding stainless steel accent piece. The side switch also features a led (seen between the switch itself and the accent piece) that is used for various purposes. The switch has very good feedback, not too mushy and not too difficult, with a barely audible click when pressed fully and released. Opposite the side switch is the USB port – capped with a snug fitting rubber cap to keep moisture/dirt out.
The orange peel reflector is quite deep and made of polished metal. The lens is tempered glass; coated and impact resistant. Inside the 5 led chips are arranged in a cross-shaped pattern, with the white led taking the center position. There is a smooth stainless steel bezel; it is easily removed to allow use of the included diffuser. On the other end of the head is a small, stout, spring where the positive end of the battery makes contact. It too is gold in color, but I'm not sure if it is gold plated.
Included in the Box
MR35 Flashlight
Fitorch branded 18650 battery (3400 mAh)
Lanyard
Clip
Holster
Spare O-ring
Spare tail switch cover
USB cord
Owner's manual
Specs
Length – 5.8 inches
Head Diameter – 1.57 inches
Weight – 6.08 ounces (excluding battery)
LED – Cree XP-L
Maximum output – 1200 Lumens
Maximum distance – 180 meters
Reflector – polished metal, filmed.
Lens – Coated, tempered, impact resistant glass
Premium type III hard anodizing (military spec)
Aluminum alloy body
Features
White + red, green, blue, UV led chips
4 regular modes (white light) (owner's manual is wrong – it states 3 modes in white)
4 regular modes (red, green, blue, UV)
4 special modes (Strobe, SOS, Strobe in red & blue, Strobe in blue)
Can use 1 18650 battery, or 2 CR123A batteries
IPX 8 waterproof (two meters submerged)
Impact resistant - two meters
Location assistance
Advanced Temperature Protection
Mode memory
Battery status indicator
Over-discharge protection
Auto power detection
Charging status indication
5 year Warranty
Included in the Box
MR35 Flashlight
Lanyard
Clip
Holster
Spare O-ring
USB cord
Owner's manual
Specs
Length – 5.8 inches
LED – Cree XP-L
Aluminum alloy body
Features
Location assistance
Mode memory
5 year Warranty
