This Bucklite Max 685 is a $25, lightweight, 4" field/hunting blade design by Buck. US-made, comes shaving sharp and great slicing performance, and they've improved the grip. I actually like this thin slicey blade geometry, and the improved grip, better than some more costly FB's I have. Also, this thing has jumped ahead of Moras in my list of favorite low cost FB's. It's a better grip, slices better, and has a full tang blade.
That said, at this price you have to expect some flaws and this knife is no exception.
Two items I'd like to improve/fix on this blade (freehand sharpening input only please
, that's how I want to work on this one):
Q's:
- Fix uneven bevel. Though the edge is extremely sharp confirmed with sharpening tests, the bevel on the factory grind is crazy wide and uneven on one side, also is inconsistent width at different points, as pictured. The bevel on the other side is half the width of the pictured bevel, and is consistent width from heel tip.
- Add a real choil. As you can see from the highlighted area, there's ALMOST enough space there to have a real choil. I can rest my index finger there, but really need between 1/8" and 1/4" extra width in the choil. I'd like to go ahead and grind one in there, making the choil both a bit deeper, and wider.
Q's:
- For item (1), what freehand process would you use to fix this, when the difference in bevel width on the 2 sides is double at some points? I realize 'leave it alone' is a live option. But this is something I want to experiment with and it's a common issue with factory grinds, so I probably won't leave it alone.
- For item (2), what steps and abrasives would you use to freehand grind a larger choil in here?
