I have 2 Hold Outs with Triads, returned a Code4, and have a new Mini Recon 1 Spear Point on order.
All triad locks i have handled had springs that were too rigid. I know many recommend leaving them open for a while. I've tried this for 2+ weeks and the results aren't what I want. The problem is that the steel does not change with leaving it open.
Those of you with engineering (material science) training know that steel has an elastic region and plastic region in regards to its flexibility. A proper spring shouldn't show any lasting change if you just flex/stretch and hold it (if it remains in its elastic range). Thats how springs work. You can flex (elastically) them repeatedly and they come back to there original position until you cycle so many times the spring will plastically deform, then cold work harden, then break. Think about your garage door springs that work for 10 years then one week they both snap. Those springs stay extended (door in closed position) for days/weeks/years and don't change their strength, until they've exceeded their cycle life.
On your pocket clips that have spring flexibility, you have to bend them beyond their elastic range (pull them up off the handle scale) until you have entered the plastic region, and when you release, the clip won't return to its prior position (against the scale).
So I'm saying/thinking that to fix the spring problem, we need to change the spring's spring rate (measure of its resistance to flexing)(how much force it takes to move a set distance). This can be done by changing out the steel spring for something else, changing the temper of the steel (heating/cooling it) or reducing the springs cross sectional area (filling down the thickness of a section of the spring (think about how a frame lock is designed). Reducing the spring rate will allow the spring to still have its design flex travel, but take less force to accomplish.
Has anyone experimented with modifying the springs? I'd like to start a discussion of how we can fix these springs ourselves and am seeking opinions and past history.
