- Jun 24, 2025
I would like your perspective on fixed blade rod sharpeners. I appreciated the lansky i used for years. But geometry got the best of me on its function. Considering that the blade lays on a plane to the perpendicular 90 degee vertical post that holds the rod and stone. The selected angle and stone and rod become effectively the hypotenuse. All angles of a triangle total 180. With the 90 degree being fixed. As the stone slides down a longer blade the triangle pivots on the same axis as the rod and stone. As the stone reaches, the blade angle by geometry must be ever more acute of an angle, while the rod end must become less acute for the rod to slide out to allow the stone to reach further. The height of the vertical stayes the same. The length of the lower side lengthens as the triangle pivots. The knife sharpening angle is more acute at the blade tip than at the point of the blade clamp. Can anyone verify or explain if this is an incorrect perspective. Thank you
