Fixing a Liner Lock?
Hey guys, I'm not sure exactly what section this should be in.
I was wondering if anyone knew how to fix a liner lock to remedy a bit of vertical blade play? The blade play is due to the fact that the liner lock has worn a bit and now when pressure is applied up or down, the liner lock wobbles a little bit and allows for that slight blade play.
I'd rather not have to send it in to the manufacturer to have it looked at since I have to cover return shipping as well and that's $14.
Thanks!
It needs to go in, not really any other options. Bending it will not fix the problem and is not something you should do anyways.
