- Sep 19, 2009
Hey guys. A thread over in the Traditionals sub-forum got me thinking about this issue again and I've got a couple questions.
I've tried the hammer fix and the squeeze-in-the-vice method. Overall I've had pretty satisfactory results. However, in my experience, either one of these methods will sometimes result in being able to see the pins in the bolsters. What do you use to sand/buff the bolsters to make the pins "disappear" again?
And then I got to wondering if the holes drilled in the bolsters (for the pin) are tapered/cone shaped? It seems if they were straight and you squeezed the bolsters together, that after a little lateral pressure on the blade(s) you'd be right back where you started - blade wobble. I imagine the pins have to be mushroomed somehow to keep the joint tight. Are they mushroomed just on the surface of the bolsters somehow and then buffed smooth, or are the holes cone shaped to accommodate the mushrooming?
Thanks in advance for all replies!
