- Jan 25, 2023
I got a little careless while rough grinding bevels today and came up on to the flat. Obviously I'll need to grind that out, but I don't have a surface grinder. My thought is to finish rough grinding the bevels, then use a height gauge to etch a line along the bottom and spine of the knife, just past the depth needed to grind out that slip, then do the same on the other side to keep things even. After that I'll use a magnet and a close eye to grind down to the line on each side. Anything I should do differently?
Bonus question: This is my first time working with AEB-L. After so googling and searching on this forum, I plan on taking the edge down to about .02" before sending out for heat treat. Is that a reasonable thickness?
Thanks!
Thanks!
