I finally got around to fixing the handle on my villager, it's one of the ones from 2 batches back. I found some brass rod stock at the locak general store (Fred Meyer, actually
). The stock 1/8" and about 3' long for $3US, enough for, maybe 20 villager handles!
Fixing the handle to the tang is as easy as Yvsa made it sound. I drilled a 1/8" hole through the middle of handle (perpendicular to the blade) and about 1/4" back from the bolster. I wish I'd had a drill press, since my hole went through at a slight angle. Anyway, I fit the brass rodstock into the hole, marked it, and cut it to length. I sanded the entire outside with 400 grit paper and sanded the ends smooth. Then I coated the first half of the pin with crazy glue (I didn't have any clear epoxy) and inserted it into the hole. Next I glued up the last half and hammered the pin home. I left about 1/32" extra pin on each end, so I put the handle on the vice and peened down both sides, dressed it with a file, and touched it up with steel wool. Total time was about 10 minutes. Handle should be good to go now (assuming I didn't cut the tang in half!). These villagers have just enough work to do to make a great craft project. Thanks again Yvsa!
Patrick
Patrick
