- Jan 25, 2026
Hi!
So I built a crude press out of a log splitter I bought. It originally came with a lawn mower engine, but it was kicking back on start up so much that I upgraded it to a HF Predator 6.5 HP engine.
(Ignore the music, I was just having fun on IG.)
The Pump itself was upgraded / replaced by the previous owner. I think it's a ~11 GPM dual stage pump from https://northernhydraulics.net/hydraulics-shop/log-splitters/two-stage-pumps . But there are no markings on the current pump, so I can't tell for sure and they all basically look the same.
Here's the rub: The aggressive half of the press-plate moves metal decently (but not necessarily straight). The flat plate barely moves metal at all. It may be too big, which I can fix.
But my motor basically never bogs down at all. With the exception of that split second where it switches from High Pump to Low Pump, the motor itself never struggles. The press will stop, won't be able to go any further. But the motor will run at the same RPM without changing.
So I'm thinking that there's more power to be had. Or is all of this normal behavior, and the only way to get more power would be to double the engine power and pump?
Thanks for any help!
