- Dec 29, 2013
Woot, first post
A few years ago I ordered a Zero Tolerance 300st, when It arrived I noticed that the knife rattled when deployed. It seemed like something was loose inside. I sent it back to KAI and w/ in a few weeks they returned it however the rattle resumed again. I did some research (kai never did say what caused the rattle) and discovered its the torsion bar inside. Instead of sending it back to KAI and have them yet again NOT FIX IT..I took matters into my own hand.
To stop the torsion bar from rattling, I simply added some grease. I used lube for my bike and filled in the groove where the bar sits. Below are pics that show the step by step. Putting it back together was a bit tricky as all parts are a bit finicky to put back in the right place, The knife is back together and works fine, its much cleaner and best of all, NO RATTLES when deployed.
I hope this helps anyone else who has the same issue.
You will need:
Grease
Hex Keys
Socket set
Patience or vodka
[/URL] Uploaded with ImageShack.us[/IMG]
remove the screws from the G10 scale. Next remove the Pivot Nut
I filled in the Groove w/ ample grease. I was concerned that the grease would squeeze out and make a mess once the knife was together. There was no mess, the lube fit in the groove and stayed.
The ZT300st opens and closes as well as the first day I got it....and its now a lot cleaner (no more pocket link)
You will need:
Grease
Hex Keys
Socket set
Patience or vodka
