- Jun 1, 2019
I have some knives that I need to use flared tubes instead of standard pins. Before I have flared the the lanyard tube, and basically glue the blade up and then redrill the epoxy out of the lanyard hole and throw the tube in and flare it.
Question is, if I am only using flared tubes, and not pins, what's the best method for glue up? I assume if I try to put the tubes in and glue up then I will get some epoxy in the counter sink....But I can really glue it up with out some sort of alignment pin. Or can I?
Anyway, if you are glueing up a knife and only using flared tubes, what's your process for glueing it up to make sure you arent getting epoxy in the countersink?
