- Mar 28, 2009
I know with flashlight nuts things like what tint the light is, and how spread a corona is and all that matter.
I'm not a flashlight nut, and I can't afford to be a nut in two hobbies.
So thing like precision built and all that stuff, while I can appreciate it, it doesn't matter, I look for lumens, I look for throw and I like battery time.
I picked up the new NEBO Redline model which boasts 250 lumens 4 hour run time, 125 lumens for 8 hours 10 lumens for 15 hours and SOS and strobe for 72 hours. It also comes with a pocket clip, adjustable beam, a battery charge indicator and the almost omnipresent magnetic tail cap.
The second is a Camping Hiking headlamp, 300 lumens, 150 lumens and strobe. It also has an adjustable beam, so you can throw or flood
Two models, one take a few AAAs the other uses a single 18650. I took the three AAA model.
I totaled about $50, I blew my Coleman headlamp out of the water for brightness for less, I'm going to keep the Coleman for reading, I modified the lens on it and now it's nearly perfect, no hot spot, flood.
I keep hearing the same things over and over about how some brands are bullet proof, or that you can't go wrong spending hundreds of dollars on a light that isn't any more functional.
Again, I know, I have knives that are hundreds of dollars, and it's because I'm a fanboy.
I really want this to be an open discussion, I would like to learn what the difference is between my flashlights and your flashlights.
My opinion is I want a light to be bright, I want to be able to choose between spot and flood, I want runtime to not suck, I want batteries that aren't an arm and a leg. I prefer to stay away from lithium, mainly because I know what lithium can do. I can pick up 40 AAA batteries for $10, for my flashlights that's 5 years of shelf life and 13 battery changes without having to rely on a wall charger. I want my flashlights to work in a power outage, so rechargeables are out the door too.
TLDR: I got new toys! http://www.facebook.com/media/set/?set=a.1094084529248.11595.1740625891&type=3&l=5ab540bdbb
