- Mar 15, 2000
I've long had a Surefire 6Z tactical flashlight that I keep alongside a Ruger P95 pistol. Just recently, thanks to the "Flashlight Snob" thread over at the Horton Knives subforum, I discovered how easily I could upgrade this roughly 65 lumen light into a more durable 200+ lumen powerhouse.
To do so, I ordered and installed a Malkoff M60 drop-in assembly. This assembly replaces the standard Surefire bulb assembly and turns a number of Surefire flashlights (6P, 6Z, C2, M2 and G2) into much brighter LEDs. All you do is screw off the lens cap/cover, remove the Surefire bulb assembly, replace it with the Malkoff M60 drop-in, and replace the cap/cover. That's it. Takes less than a minute.
Here is the description of the M60 found at http://www.malkoffdevices.com/
And here is a picture of the drop-in.
Below are some contrastive beam shots. I took these with my camera in a tripod (flash turned off, same conditions for each pair) so I got the same shot for comparative purposes. The indoor shots were taken from approximately 8 feet away as I shone the Surefire 6Z flashlight onto the blankest wall I could find in my house.
First the Surefire bulb assembly...
And then the M60 drop-in...
With the M60, the entire room was noticeably brighter. The above pics don't really do justice to how much better you could see objects throughout the room.
Then I went to my backdoor (it was raining outside) and shone the light up into a tree approximately 30-35 feet away. Here's the Surefire assembly...
And here's the M60...
You can see the M60 drop-in adds a much more intense, more clearly defined white beam. For me, it was well worth the $60 upgrade cost, especially considering the durability that this new LED assembly is supposed to add. The Malkoff assembly reportedly handles bumps and shocks much better than the original Surefire incandescent assembly. I like the upgrade so much that I'm planning to pick up an older Surefire 6P original for my vehicle and install the same Malkoff drop-in.
This is the Malkoff Devices P60 style dropin with solid brass heatsink construction. This design utilizes a Cree 8 degree optic. The optic has a very nice balance between throw and spill. It is an outstanding room lighter and short to medium spotter. It was designed specifically for use in SureFire 6P, 6Z, C2, M2 and G2 flashlights. It may or may not fit other models. The input voltage is 3.8 - 9 volts. Below 3.8 volts it will drop out of regulation and run direct drive. The output is 235+ lumens. The current draw is only 750ma at 6 volts. The runtime is 1 1/2+ hours on 2 CR123 primary batteries. It will easily illuminate objects at 350+ feet and will blind opponents within a 100 foot radius. The LED is a Cree XRE 7090.
