- Dec 10, 1998
Ok, I was bored at work. There is a fixture there to modify kennemetal tool holders. It is U shaped and is ground at a 10 deg angle on the top and flat on the bottom with set screws to hold the tool holder. So I took a piece of O-1 barstock, and cut out the profile on the bandsaw and clamped it in the fixture. I made about 6 passes and made a perfectly flat tapered cut on the stock. I fliped the blade around and did the same on the other side. I have never gotten a more perfectly matched ricasso. The finish was prety good also. I'll post a pic this week. I wa also thinking of indexing the head on the milling machine to 45 deg and using the edge of an endmill to cut a hollow cut, like a hollow grind on a piece of stock. anyone else ever try this?
Thanks,
Chuck
Thanks,
Chuck
