crocogator106
- Nov 16, 2012
What angle should I grind each side of 3/16 A2 knife? I want to try a full flat grind. The knife blank is about 1 1/2" wide.
The first picture shows a triangle, which is what the cross section of the area would look like if you cut a slice out of your blade.
The second picture shows a jig like piece next to the platen.
Theta = arctan(opposite/adjacent)
I believe in giving you just enough information to help you LEARN what you would need, when it comes to this type of stuff, like math etc because you will need to know how to do it in the future no matter what other people tell you.
Solving for theta in the first picture wont give you the exact angle that you will need on the platen, it really depends on the type of jig etc that you are using, so it is hard for me to tell you exactly what is what with that angle.
This does not take account of the edge thickness. In general a knife is ground to a tall trapezoid, not a triangle.
